87 v20
John81287
Mchenry,IL
V20
Hey guys,
I completely new to the square body. I have an 87 V20 that is going to be my project truck. I am looking at picking up an 85 C30 for the motor and front clip. The C30 has a manual trans in it. My V20 has an automatic. Can anyone offer some insight into what issues I may run into on doing this swap. I would like to keep the automatic transmission in the truck. Is it a direct bolt up to the new motor or do I need to make modifications to get it to link up. Any input is greatly appreciated. Thanks :025:
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Hey guys,
You will definately need a different flywheel for an 85, as the balnce is different on the pre 86 engines due to the rear main seal setup from 2 piece to 1. Are you keeping the EFI too?
John81287
Mchenry,IL
V20
Yes I am doing a complete cab swap so all the electronics from the C30 will come over to the V20.
John81287
Mchenry,IL
V20
My mistake. I'm going to keep looking for a reg cab with a 454 model yr 1987. Truck doesn't have the throttle body any longer. But I'd like to get it put back in. Thanks for the input
Jims86
Patterson,Ca
5.7 TBI
Ok, you know you are giving up around 50 hp/tq by using the 85 engine? Unless the c30 is a 454 of course.
John81287
Mchenry,IL
V20
It is a 454. That's why I want it so bad!
Jims86
Patterson,Ca
5.7 TBI
Ahh, ok, we posted at the same time. The trans in your v20 should be a TH400, so its a good one to put behind a 454.
I personally would recommend a 454 out of a 95. still TBI Like the 87, but you can run a4l80 later if you want. The fuel pump, pCM and harness are needed also. The 94-95 454s run 30-33 psi at the throttle body, opposed to the earlier ones, which run 9-13 psi fuel pressure.
John81287
Mchenry,IL
V20
Thanks for the info. I may just stick to the carb motor and be done with it. Haven't quite made a decision yet.
Jims86
Patterson,Ca
5.7 TBI
As long as its QJet or Holley, yer good.
John81287
Mchenry,IL
V20
Ok thanks. The truck is kind of a patchwork quilt. It's and 87 with a carb 305 in it. Engine was rebuilt/ replaced at some point. So this is why I'm leaning towards getting the carb 454 to put in it. How can I tell if the flywheel on my 395 will work with the 454? Or is it guaranteed that it won't? Thanks again
John81287
Mchenry,IL
V20
305* damn fat fingers!
John81287
Mchenry,IL
V20
Am I going to have any issues with engine block length? Driveshaft lengths? Transmission location?
John81287
Mchenry,IL
V20
I assume ill have to relocate motor mounts which I fully expect.
Jims86
Patterson,Ca
5.7 TBI
Ummm...i dont think youll have a problem with any of that stuff
br562g
