87 V10 driveline
WP77
Naples, Idaho
Steven
I'm in need of a driveline for an 87 V10 longbed. I haven't found one yet, but have found a couple for Suburbans. Weren't the long beds and Sububurbans the same wheelbase? If so, would the driveline be interchangeable?
Chevy 88
Canada
f7t6
GMC
Have you checked eBay?
WP77
Naples, Idaho
Steven
Yes that's where I've been looking.
Chevy 88
Canada
f7t6
GMC
How about car-part.com ?
Its like... Every junk yard on the planet, all in one place.
What are you actually needing? A drive shaft? An engine,transmission and rearend?
WP77
Naples, Idaho
Steven
I ordered a rebuilt transmission and transfer case. Now I just need the driveline. Lost all 3 in the fiasco.
WP77
Naples, Idaho
Steven
I've used them before and will check. It's weird on Ebay I can't find a single one.
So you need a driveshaft,just the rear one? Or both? Use drive shaft as your search criteria not drive line. I think you'll have better luck. I believe there is a couple inches difference between burb and pickup on wheel base. Doubt it's a swap. Also unsure if carrier bearing is in the same location.
I was concentrating on the question of burb to pickup interchange,not concentrating on what else may fit your vehicle. Didn't occur to me until later,the reason you are having a problem is tge V series pickup was 1 year only. Try looking for 82-86 k10. I stumbled across these guys all they do is driveshafts. There's also Dennys driveshafts but I think when you start using drive shaft instead of drive line and including k series,you'll find a driveshaft in a few minutes. Driveline to me has always meant any part from the flex plate to the wheel hubs. Where as drive shaft has always meant the propeller shaft from the transmission or transfers case to the differential.
Moderator
The Suburban drive shaft is a couple inches shorter than that of a longbed pickup, with all else being equal (trans, t-case, rear axle).
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Wheel base is the same?
WP77
Naples, Idaho
Steven
I think burb is 2" shorter
I found a new one and ordered it. Just searching for drive shaft instead of driveline solved it. Thank you
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
bajadiver
