87 R10 LWB Lift
akchevrolet
Andrew
R10
Can I just add say 3/4 ton coil springs to front to lift the front or would I have to change anything else. I just want it to sit a little taller. then I might do something to level the rear with the front if have to.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
1 ton big block springs might raise it up a little, but it'll ride rougher. There used to be a company that sold a lift for 2WD Squares, but they are long gone.
akchevrolet
Andrew
R10
There was a thread where a guy had a c20 that had ld coils and changed to c30 hd coils and got a 2 inch lift.
Swims350
Logan WV
none
you very much could get some hd, big block or 1 ton springs and raise it some or even spring spacers. The ride will suffer or become harsh either way
Swims350
Logan WV
none
no clue on that stuff I really don't think that kit in the link is right thought it looks more like a newer truck kit. It does say c10 though
akchevrolet
Andrew
R10
Alright thank you sir. now just need to get the money then find the right shocks too since itll be taller and mine r bad neways just waiting to make it taller before buy new ones
