87 burb 3/4 drum rear brakes
Italianwagon
Washington
Steve
V20 Suburban
Hey
seen a bunch of posts about adjusting the drums. Just redid them and what’s the best way to adjust them?
Jethro224
Illinois
Only one way.
Jack it up, neutral, adjuster spoon or screwdriver thru the little window in the backing plate to turn the adjuster wheel.
Spin the tire while you're adjusting until you feel a slight drag then pump the brakes and check it again.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
You can do what he just said, and get it close, then go in a open field or parking lot, go in reverse and stomp the brakes (in reverse) until you start to feel them drag.
That method I just stated takes a long long long time if you don't have them adjusted closely, so get it close to start
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If you're going to use the self-adjusters you have to repeat forward brake application, reverse brake application. Hitting them in reverse only works once.
I believe the manual says to tighten the adjuster until the wheel can't be turned by hand, then back off until the wheel turns without drag.
My method, although not "approved" is to adjust by play. Use a screwdriver to move the adjuster back and forth. You want between 1/16" and 1/8" of movement.Try for closer to 1/16". Don't pry too hard, you want free movement, not forced movement. No need to jack the vehicle up this way.
Jethro224
Illinois
The self adjusters are only there to kinda sorta keep them adjusted during normal driving after they've been adjusted manually.
They don't necessarily adjust evenly and the brakes probably didn't need exactly the same adjustment when you hung the shoes. And the self adjusters don't know or care how loose or tight they are, they just kick em a tooth or so whenever you stop in reverse....maybe...
WebMonkey
Army
Missouri Ozarks
my k20 self adjusters work with the parking brake.
(each time i set the parking brake, the self adjusters will advance IF there is any advance waiting to be sprung)
they do not advance on a brake while reversing.
i would definitely jack up the tire.
advance the adjuster with a screwdriver, then test spin the wheel.
rinse and repeat till a revolution is all you get from a spin.
good luck
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
good luck
How is yours different that it works that way?
WebMonkey
Army
Missouri Ozarks
i guess the 13" drums have different hardware?
the parking brake lever in the drum assembly mechanically effects the adjuster assembly.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
AFAIK they all work the same way. It's the rotation of the shoe assembly in reverse when it has excessive clearance that moves the star wheel.
If you have a picture of yours I'd be interested to see it.
WebMonkey
Army
Missouri Ozarks
these are in the 'webmonkey's k20' thread'
the parking brake cable effects the self adjuster.
i watched the lever/levers/shoes when a 'helper' depressed the parking brake pedal.
I am certainly NOT a mechanic, so i could be wrong.
newer disc/drum setups used the parking brake.
drum only setups used the reverse it mostly since no parking brake attachment to the front drums.
imports loved the parking brake adjust method.
i don't know, don't mind me.
i have owned/operated both types with varying degrees of satisfaction.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Just did my rears on the 14ff, adj close to drums, slight drag, when you put the drums on.
Vbb199
Salisbury NC
Vince
I noticed you're using Pittsburg 3 ton Jack's.
Do you still have legs? LOL
Italianwagon
Washington
Steve
V20 Suburban
Sweet. Thanks got them all adjusted and working great! Time for the front brakes lol
WebMonkey
Army
Missouri Ozarks
those are the 'replacements'.
i didn't have any to begin with though.
i checked the number and they weren't listed in the NEW recall but yeah, i'll be watchin' those.
Joestreml
