86 single cab long box
Chuck
Grande prairie
Chuck
K30 crew cab
This is the truck I got for free. 4
8 inch blocks front and back came with dana 44 12 bolt and welded 14 bolt ff with 42 inch vtreads. I pulled the motor 350 cammed it with torque cam and intake. Still have to replace bottom bearings. Grabbed a dodge dana 60 for 150 gonna drop that in and weld the collar in place. Installing the 52s 10 lifted out of my 81. I plan to run 63s with lowered hangers to match the front. Gon at do cross over witch will be easy cause dodge already run cross over. I am in the middle of making hydro assist for both trucks combine steering rams cheap from the tractor junk yard.
Chuck
Grande prairie
Chuck
K30 crew cab
Today I am mounting front springs
the 52 beyond is a awsome kit but if I didn't jump my trucks you can always just switch hangers from side to side for 52s. I just grind off the rivets and beat them off with punch and sledge
Chuck
Grande prairie
Chuck
K30 crew cab
gonna figure out how iam gonna attach the dana 60 and the drivers drop t-case iam gonna use out of a 95
350runner
tx
Ceasar
This is going to turn out good. Wish I had a reason to build something like this.
Chuck
Grande prairie
Chuck
K30 crew cab
One day it will hit the highway but till I get tires and a better front axle it's bush truck. One ride in my truck would give you all the reasons you need to build one. We trail ride here happens to be a lot of mud but we hill climb no rocks tho
BigPapa
