84 k5 driveline vibration
Jordanc
Bayfield wi
jordan
K5 Blazer
so i recently picked up a 84 blazer thats got a 4 inch lift, i really dont know much at all about the truck, what i do know is that it has a 350, with a th350 transmission, not sure on the transfer case, but under acceleration its got a pretty good vibration, letting off the throttle it does go away, kinda stumped on this one but i do know the drive shaft in it for the rear is not factory
RoryH19
Rory
R10 Silverado SWB
Looks like a np208 transfer case.
The rear driveshaft is not original, looks like they put a SYE with double cardan joint. Really don't need one for a 4" lift but it's an upgrade.
Also noticed the axle yoke appears to be pointing down instead of parallel or slightly up.
You will need to check drive shaft angles.
Jordanc
Bayfield wi
jordan
K5 Blazer
to be honest i looked at it again today, and it doesnt look like it has a sye it looks like a sye thats put in to a slip yoke im not sure if thats right
Jleopard77
