KamperBob
- Mar 16, 2024
- Somewhere USA
- Robert
- k30
I'm hoping y'all can help set proper expectations. My 6.2 developed a fuel leak that I'm trying to chase down. From research I've pieced together some information. If I understand correctly, the primary fuel circuit (stock) would be a follows. From dual tanks supply and return lines meet at the selector valve. Then a single pair goes up under the hood. The supply line goes on to the lift pump (mechanical) on the front passenger side of the engine, inside the frame rail. From there fuel flows up to the filter on the firewall. Then over to the IP on top of the engine, under the intake manifold. Presumably entering the IP at the rear. The IP return line (probably also rear) goes back down to the tank selector. Do I have that correct? Or am I off target somewhere? Any visual aids would be a major blessing to lay eyes on everything under a less than ideal work area in eleventy some temps. Thanks a bunch!
