82 K20 Oil pressure
82ChevK20
Canada
Gabe
R20
Is this oil pressure too low!?
This is right after start with motor warm
And at idle
When I give it some gas it goes up just under 30
Running 10w-30 conventional
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Have you verified with a mechanical gauge?
82ChevK20
Canada
Gabe
R20
No, but I'm almost sure the stock one is operational. I know the rule is 10 psi for every 1000rpms and it idles at about 700 so its probably ok?
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Operational, yes, but may not be accurate
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Could be a bad sender. Or wire is bad.
Yes but what is it is accurate is the pressure ok?
Who knows? It's probably fine, but if your gauge reads 10 lbs high,because it's inaccurate,then no your pressure is too low. I wouldn't bank on the gauge being off,but nobody knows for sure. If you aren't hearing lifters clicking you are probably just fine.
82ChevK20
Canada
Gabe
R20
It runs smooth as a dream so
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
As @Ricko1966 stated, probably fine, but it does need to be verified with a manual gauge
seattlesquare
