80 clip swap on 86
mopar458
Wv
Clifford
I have a 86 gmc Sierra and a 80 chevy Scottsdale. I want to put the 80 clip on the front of my 86. Just wondering what all needs to be done for me to do it
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
take the parts off use the body mounts to match the year of the frame. then put the parts back on
pretty easy swap going to the older clip
mopar458
Wv
Clifford
So i have to take the core support off my 80 nd put on my 86
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya core support both fenders and hood
you will need to remove the cowl panel from the newer truck the older truck hood covers that area
basically all the sheet metal in front of the doors needs changed
MadOgre
NA
NA
NA
NA
NA
What about the hood hinges ?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
they bolt on the inside of the fender on the 80 and older trucks
they should stay on the fender when you swap it
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
oh ya the frame horn where the bumper bolts on is different
I have just cut the frame horns off in front of the core support mount and swapped them just weld them back on.
not sure about any other ways to swap bumpers
MadOgre
NA
NA
NA
NA
NA
I thought on 80 and older the hinges recessed into the cowling area when the hood is closed ?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
that's 81 up
if he was putting a 81 up clip on a 80 older truck he would need to cut a hole for the hinges.
but putting the older clip on a newer cab no need to cut for clearance
mopar458
Wv
Clifford
Good deal so shouldnt be to awful..
MadOgre
NA
NA
NA
NA
NA
that's 81 up
Ya ok I must of got it backwards with my old age lol. Just checked out some pics to double check and yes it is just as you say. I don't know how I got that switched around in my head:whymewhyme:
mopar458
Wv
Clifford
If u got some pics post some of the swap
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
yeah that is an easy swap I would just pull the 80 clip as 1 piece and bolt it on the 86
mopar458
Wv
Clifford
Thats what im going to try. Only things got me a little worried is core support and frame horns for bumper
chevyman82
michigan
Ryan
k1500
Hope you don't care about windshield wipers because the older Hood will hit the wipers on the newer cab so your going to have to modify the Hood or go without wipers either way it kinda sucks
imyourhuckberry
