73 c20 350 How does she look?
73OLyellow
San Diego
Marcel
Hey guys just got this truck and really have no idea how bad or good the shape is under the hood. Can you guys tell me what I have? Is the fuel filter inline or is it in the carb?
350runner
tx
Ceasar
In the second pic you have two spark plug wires laying on the exhaust manifold. That's not good. If they show burn marks I'd replace them. The voltage well leak to the closest ground.
73OLyellow
San Diego
Marcel
Thank you! So just stick them straight up? Is the fuel filter in the carb or is it in line?
350runner
tx
Ceasar
Yea I'm diff from must I don't like my plug wires touching any metal. The carb fuel filter is(see pic)
Here's a good read that shows a qjet disassembled. http://www.vetteprojects.com/kstyer/quadrajet_2.htm
MadOgre
NA
NA
NA
NA
NA
I would hunt down a full length steel fuel line from the wreckers for safety reasons.
MadOgre
NA
NA
NA
NA
NA
well they don't leak on to your hot cast iron intake causing a fire!
73OLyellow
San Diego
Marcel
Thanks! I tried this but I think I did it wrong there was no filter, or maybe I only took off the front part.
MadOgre
NA
NA
NA
NA
NA
That 90 fitting threads into that fitting in the pic then that into the carb. You will need a 1" wrench to open it. Sometimes guys don't put filters in there cause they think they are improving performance lol which is fine if they have installed an inline filter but bad if they have not.
73OLyellow
San Diego
Marcel
Is this where the filter is located?
MadOgre
NA
NA
NA
NA
NA
Yep
MadOgre
NA
NA
NA
NA
NA
Take that fitting off then the one behind it as well
MadOgre
NA
NA
NA
NA
NA
Be careful when reinstalling the 1" fitting back into the carb. It is very easy to strip the threads on the carb body so just use your fingers to thread it in and the wrench to cinch it tight. Not to tight though!
73OLyellow
San Diego
Marcel
I also thought this was a fuel filter too? What is this? And is there a diagram of all the engine components under the hood? I cant find anything like that online. Or manual.
sever
