73 c10 wiper issue
eskimomann209
Modesto
Marcus
I installed the wiper motor and arms and it’s stopping 1/2 way through
I think my issue is the wiper motor is from the 73 and the linkage is the 78s?
Is there a variation I need to know about?
eskimomann209
Modesto
Marcus
The output shaft in the 73 seems longer than the 78s
Like a dumba$& I tossed the linkage from my 73
There is a difference in the crank arm that bolts to the motor, but I don't remember what the difference is.
So the wipers just plain stop, or they go halfway and then return again?
eskimomann209
Modesto
Marcus
The length of stroke is correct
But the home position is square in the middle of the stroke
Oh, that kinda rings a bell. The crank arm "flats" must be clocked differently.
When parked, the crank arm should be sitting relatively level.
eskimomann209
Modesto
Marcus
Ok update
The transmission arms are the same
73-80
The motors changed in 77 so the crank arm also changed
Here are pics of the two styles
eskimomann209
Modesto
Marcus
Initially I figured only the offset was different so I shimmed out the motor.
Turns out as you can see the timing is different too
jodygraham64
