700R4 Speedometer Drive Adapter
johns87
Orlando, FL
I have an 87' with a 700R4. I recently replaced it and connected the speedometer cable thru the 90 degree adapter. The speedometer had been disconnected a few years back and it didn't work. Long story short traced it down to the adapter. I'm guessing the gears inside are shot as it will spin only on side.
I connected the cable straight to the transmission and now the speedometer works, but with out the adapter it is off. The adapter shows a 1:0.90 ratio on it. So, I started trying to find one and seeming pretty hopeless. I've seen a couple on eBay but seems pretty expensive.
Are there any other options? Oh here's an image what one looks like.
4WDKC
Southern Florida
Kacy
find the right gear for the tire size and gear ration you have. Install on the cable thing in the transmission.
yevgenievich
Place
Name
Year
Model
Size
I just sold one on eBay for $50 couple of weeks ago. But I think sometimes adapter got used when exact gear combo was not available. Maybe could find better matching spedo gears or change tire size
johns87
Orlando, FL
I'll give that a shot then, I appreciate it.
I just wanted to make sure it wasn't needed for some reason I couldn't figure out.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I think I have that exact adapter with the ratio your looking for. Let me know if you still need it and I’ll post a pic
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Well, crap. I do have that exact adapter. It’s obviously missing some teeth internally. When I turn one side of the adapter, there is a point in the other side where the rotation stops for about a 1/4 turn. Bummer
Danger Dave
