- Mar 9, 2025
- Colorado
- Mark
- GMC Jimmy K5
Hey all, this is my first 700R4. It had a whole bunch of nastiness in the pan when I first got it and changed the filter and fluid about 3 months ago. I have also replaced the TV cable and adjusted it to spec. I have removed and cleaned the 1-2 shift governor to ensure proper movement of the internal parts.
My problem is it will shift perfectly sometimes and other times it won't shift 1-2 or 2-3 unless I'm at or higher than 3000 rpm. There is no slippage of any of the gears/clutch packs. When it does shift, it shifts good and hard, so I don't think I need a rebuild.
Am I thinking correctly that there may be more gunk in the valve body not letting the pistons/rods move freely and it's taking a higher rpm to get the pressure up to move them if they are stuck?
Can I just remove the valve body, clean and ensure things move freely and replace?
What is your opinion on having it back flushed?
Thanks for any input you guys have.
