700R4 Shift Kit Recs
My truck's 700R4 is good as far as I can tell, but I think the PO put a ****** (probably B&M or the like) shift kit in it, and I think the kit's ****** 1-2 accumulator spring broke. I've got late shifts with a good TV cable setting, a nasty 1-2 shift that wants to throw you out of the truck, and it's really squirrely in OD. By that, I mean it would much rather be in third, and when it's finally sitting pretty in fourth, it'll over exaggerate the need to shift back to third, and the cycle repeats. I'm guessing it has something to do with the off kilter shift parameters and/or the TCC is unlocking too easily. I'm no transmission expert, but that's my hypothesis. I know it was discussed in the effed TH400 thread, but there seemed to be varying conjecture. I want a crisp shift to eliminate slippage, but I'd like to keep it low on the spectrum in that respect. The Transgo seems good, but what do you guys think? Is there something outside of the mainstream that could be overlooked?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Well I don't have the experience as my 700 is still hiding and not in a truck shifting. I bought this tran from an old geezer who has been building them for 40 years. He is retired now but still rebuilds at home. He's well known around Vancouver BC. He was considered a 700 specialist by the hot rod gang. He said the Transgo is the one and only to use. Said the BM shifts too hard and blah blah much of what Jesse said above. Causes other problems down the road.
And for curiosity... he states that there is a big difference building 700 for street/strip fun vs. 4x4 truck/pulling.
74 Shortbed
He is correct B&M is ****, Transgo is the only way to go, for any tranny for that matter..
As far as use goes, nothing too fancy. Cruising, errands, and pulling small loads. I figured the Transgo was the one to go with. The thing that worries me is not knowing how long mileage wise that garbage has been in there, and if it's caused any damage with all that horse and buggy shifting. Jeez, I know what stock shifting 700R4s and TH400s feel like, and it's not that at all. When I serviced the transmission, there weren't any of the destroyed transmission clues in the pan, but I worry about the stuff external to the transmission that could be affected by those shifts.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Easy shift kit switch to type F
I've seen you mentioning that before. What does the Type F do over the Dexron III?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Firmer shifts. Type F doesn’t have the “squishy” agent that produces granny shifts like Dextron does. Lincoln’s use Dextron lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It’s basically like B&M trick shift just way way cheaper. Pretty much if I go to Wally World I will buy the 3 or 4 bottles they have on the shelf lol type F that is
The thing that worries me is not knowing how long mileage wise that garbage has been in there, and if it's caused any damage with all that horse and buggy shifting... I worry about the stuff external to the transmission that could be affected by those shifts.
For example, I know I can sometimes hear a "woooo" sound coming from the rear diff. If I let off the gas, it'll go away. Otherwise, I know I'm okay on the flexplate and the motor and trans mounts. I worry about that G80 grenading on me from prior abuse or stress from that choppy transmission output. God, I'm so weak when it comes to trans, t-case, and rear end stuff. I really need to get it together on that.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
For example, I know I can sometimes hear a "woooo" sound coming from the rear diff. If I let off the gas, it'll go away. I worry about that G80 grenading on me from prior abuse or stress from that choppy transmission output. God, I'm so weak when it comes to trans, t-case, and rear end stuff. I really need to get it together on that. Otherwise, I'm okay on the flexplate and the motor and trans mounts.
Find junk stuff and take it apart see what’s inside and first and foremost don’t hold your self back or be intimidated it’s just nuts and bolts
I agree. I’m gonna get into the transfer case pretty soon. I’ve got a small leak, although I haven’t looked to see if it’s a seal or if it’s leaking at the split.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Well if you pull it apart have a tub of auto trans assembly lube handy to stick the double stacked needle bearings to the shaft. Also pack rags around the inside of the case so the needle bearings don’t fall into the planetary assembly because that’s where they are gonna go. And definitely replace the selector feet Main killer of the 208 is misengagement
jon wandvik
