700r4 help
Mechnoob93
Las vegas
Anthony
C10 silverado
If anybody could help would be nice so my c10 came with a 305 700r4 engine gave out so I put a 350 from a 69 Corvette and a few mods. So I adjusted my shifter on the steering column truck ran ok but then it wouldn't move on drive. It shifts in all gears but jerks hard on 3rd and then it moves idk what's wrong reverse works fine
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
4WDKC
Southern Florida
Kacy
did you hook up and set the tv cable that runs from the carb to the transmission?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Ok, I need some clarification. Did you swap the 305 ENGINE for the Corvette 350, or the 700 trans for a 350? If you swapped engines, unless the shifter adjustment was moved while the engine was out and the trans was hanging, the engine swap shouldn’t matter. The shifting characteristics could have changed if the TV cable isn’t adjusted the same or adjusted correctly.
If you disconnect the shifter rod from the column to the trans, will both the column and the trans move they the entire range of movement smoothly and without binding? If not, that needs to be corrected before going further.
If you swapped the 700 for a 350 trans, the steering column shifter has different “gates” with specific detents for each gear.
The 700 column will probably work ok, you just need to be sure that it will line up close enough in park, reverse, and drive. Your probably not going to be able to get the detents to line up with every gear, and the neutral safety switch may not work in both park and neutral since the distance between each gear is a little different.
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
Mechnoob93
Las vegas
Anthony
C10 silverado
Yeah I clipped it on the transmission I even took out the governor thinking maybe that was it
Mechnoob93
Las vegas
Anthony
C10 silverado
The 350 engine from the Vette to my c10 the 700r4 was already in the truck im not sure how toadjust t.v cable I just reconnected all the wire n stuff adjusted the shifter rod according to the service manual
Mechnoob93
Las vegas
Anthony
C10 silverado
I connected the TV cable from the tranny to the carb I don't have anything connected from the tranny to the actual engine
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Make sure the carb will go to WOT by flooring the pedal. Make sure the floor mat, carpet, etc isn’t holding the throttle from opening all the way. Once that’s done, push the locking tab on the TV cable, slide the asjuster all the way back, then release the lock tab. Floor the gas pedal again, you should hear the TV cable adjust. You may need to move the cable adjustment in or out a few clicks to dial in shift points.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
hey matt69olds i suspect i am not getting wot, where would i make the adjustment? bend the pedal assy.?
ssgleoleal@yaho
West covina
Leo
V1500 Suburban
not the peddle. You need to set the TV cable when at WOT throttle. Easy stuff if you know how, if net, take it to a pro. You can easily destroy the 700R4
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You can bend the throttle bracket on the carb, bend it at the gas pedal, whatever it takes. Don’t open the throttle from under the hood, you need to make sure the carb goes WOT with the pedal. Hope that helps
samelthecamel19
