What would be the best one from rough country?
I wanna go from a 6 inch lift to a 4 and I'm only building my truck to be a mall crawler so will the 56 inch ones be good and clear my 35s
Thanks that helped out a ton, what's a good offset for a 4 inch lift?You're comparing 2 different suspects of the rear springs, length and lift.
4" lift can usually clear 35's but wide rims can cause rubbing, especially in turns.
52" vs 56" refers to eye to eye spring length, specifically the rear springs. If you choose to go with a different length than original there are rivoted brackets to be moved. Also the center pin placement is different between the 2 lengths, one is centered and one offset (both being 26" from front eye to pin).
Spring length is measured from center of the eye to center of the opposite eye following the arc of the top leaf (NOT straight across above the leaf).
For a mall crawler, keep life easy and stay with whatever your original length measures.
