5.3 swap, need help with fuel tank question
Houston Ben
Houston
Ben
Hi AJ,
Is that the original drier for a 85 chevy? also, where can I get the hoses to attach to the compressor if I go with a top mount?
Thanks guys!
AJII
Jackson, TN
AJ
Yep. That's the original drier.
Hoses I had custom made at a local hose shop. ~55 each.
Boone83K10
Boone, NC
Benjamin
Uhhhh maybe I am not looking at that pic right but isn't the air inlet facing the wrong way. How does it go into the engine if the opening is facing the fan shroud?
AJII
Jackson, TN
AJ
Huh?
AJII
Jackson, TN
AJ
Maybe this will help..
Houston Ben
Houston
Ben
Thanks again AJ, I should have my engine and trans on Tuesday!!
Houston Ben
Houston
Ben
Hey AJ, I have another question on the Holley A/C bracket. Do you remember what part numbers you needed? I see I need Partn number 20-134 but it also says I need part number 21-3 but 21-3 sounds like it comes with spacing for the a/c, p/s, and alt, all I need is the a/c one so wont part number 21-1 suffice?
If you could, please let me know what you got
Thanks,
Ben
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
If you run any rubber line, insist on SAEJ30R9, Also, i believe the 2011 system is regulated at the tank, you may will have to rig up a return line to work with the 87 tank. I dont think the fuel rails from an '11 has a return provision, so you can get an adjustable regulator to mount back by the tank, which will only require a short return line.
AJII
Jackson, TN
AJ
You'll need 21-3 as well. It comes with the specific brackets that work with truck accessories.
AJII
Jackson, TN
AJ
He'll just use the vette filter which has a regulator built into it I'm guessing.
Houston Ben
Houston
Ben
Thanks for the help guys!! Forgive my ignorance on this, it is very new to me.
Jims86
Patterson,Ca
5.7 TBI
Never heard of that...makes for an exspensive filter.
Houston Ben
Houston
Ben
Hey Guys,
Regarding the fuel issues and not knowing which system I have or what I will need for it I have attached pictures with questions on them if you would be so kind to help me out.
Thanks,
Ben
JOD26
