4l60e and a 307 gear.
mpc_hayes
Kannapolis NC
Michael
OK heres what I am doing. I got a 350 vortec out of a 99 tahoo and its going in my 77 2wd c10. I am putting the 4l60e in and was wanting to know if the stock 307 rear end is going to act with the over drive. Do I need to go with something bigger'?
Boone83K10
Boone, NC
Benjamin
truck will probably almost be idling when going down the highway. My 3.08s and 700r4 are barely at 1350 rpm.
We both need a lower (higher number) gear. I want 3.73, only bad part is I need two sets for both axles. You need only one. I hear you will actually get better MPG with a 3.73 since the trans won't be in and out of high gear on the slightest incline.
also, welcome to the forum. I am from Mooresville, NC originally so I've been to the Knap a few times.
MrMarty51
Eastern Montana
Martin
Beautifull cruiser for flatlands and ninety miles an hour.
Just keepit in third when driving around the slower roads then shifter into OD when You get into the flat lands a minimal traffic.
Wo`nt be real quick off the line either.
Driver4r
Nebraska
Trevor
k10,c20
Go With 3.42's, its a beautiful gear for 2wd.
gpmorgan
Tupelo Ms.
greg
My 92 had 308 rear gears and a 700r4 when it was new. They worked very well together. 21mpg on the highway. I'll admit I thought it was a little under powered, but then again, it only had around 200hp. If you want to really feel it in the seat of your pants, 373 gears should do it along with a limited slip carrier. If you want fuel economy, keep the 308 gear. The 342 gear is kind of an all around gear and would also be a good choice.
mpc_hayes
Kannapolis NC
Michael
Thanks for the info. I think I am going to leave it like it is. I am not going to be towing with it. I am making a daily driver.
Heres the truck. I have had it for 13 years, 10 of witch it sit in my back yard.
I got the rebuild done on the vortec 350 now I need to finish the 4l60e , New gas tank, Fuel pump, Get drive shaft cut, build wiring harness and get the PMC flashed. Tires and rims , FUN
gpmorgan
Tupelo Ms.
greg
Looks like a good straight body. I think you will like your choice of gears espically when you pass the gas stations.
mpc_hayes
Kannapolis NC
Michael
Just need a new hood. Mines got bent, And Thinking of getting some bumpers for LMC
