40 gallon suburban tank in reg cab ?
sean1960
Wylie Texas
Sean
Custom GMC
Ok then... Liftmeup lets get back to your original question. Tell us more about the truck you want to put the 40 gallon in. Is it stock, 1/2 ton, long wheelbase, 4 wheel drive? I wouldn't be to concerned about the extra weight of the gas. If it becomes an issue then beef up the springs to compensate.
liftmeup
south central pa
liftmeup
k20
k20 so I think there will be no issue with the weight if anything it will ride better empty and maybe I can backup a hill without using 4 wheel drive now lol... If it does not work out I will mount 2 new 20 gallon tanks and use a ford transfer setup so there is only one filler neck. My truck has a plow rig on the front so there will be no steering loss from burb setup
sean1960
Wylie Texas
Sean
Custom GMC
Sounds like it will work to your benefit. Let us know how it turns out.
Could you please explain more about the ford transfer setup?
jon wandvik
