4 speed to th400 swap
joninva
Rockbridge Baths, VA
Jon
k30 3+3
i have an 82 3/4 ton 350, 4 spd. 4x4. have access to a 454 w/ th400. what do i need to bolt the 400 up to my transfer case? the donor truck is a k30. i can get the crossmembers and column. will my transfer case need to be moved back? if i just go with the 454 and keep my 4 spd, will i just need a bellhousing? thanks
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
You'll need a TH400-specific NP205. The input shaft of the NP205 is female, which is an oddball compared to other transfer cases.
crazy4offroad
Curt
K-10
350/SM465/NP205
attachment.php
crazy4offroad
Curt
K-10
350/SM465/NP205
You may want to look here:
http://offroaddesign.com/catalog/transfercaseparts.htm
"NP205 parts
NP205 input conversion Kit:
Convert your male input NP205 to a TH400 version 32 spline short female input gear. Kit includes new input gear, input bearing and a seal and gasket kit. Requires machine work on the NP205 case to install, the input bearing bore must be enlarged by about 3/8" compared to the small bearing."
incase your search for one doesnt pan out.
nvrenuf
Mobile, Al.
What years the k30? This will effect which 205 input you need.
As for swapping to a 454 and using your 4spd, the trans is good to go as is you'd only need the correct flywheel for the 454.
If it's an '85 or newer, couldn't a 32 spline np208 also be used? That's what's behind the '82 3/4 ton sm465 that's in the truck already, isn't it?
nvrenuf
Mobile, Al.
I got my head stuck on the 205.
Yes, the '82 32 spline 4spd will bolt up to a '85+ 208 assuming you have the correct adapter (4spd to -> up to '84 figure 8 pattern vs '85+ round pattern).
The t-case & year of the K30 will will make a difference on which tailshaft the th400 has which will effect which case fits.
joninva
Jon
k30 3+3
more info
thanks for the replies. both trucks are 82 models. i think my k20 has the 208 t-case. so it sounds like the th400 from the k30 won't bolt up to the 208 in the k20, right? so if i keep the 4-spd in the k-20, the bellhousing will bolt up to the 454 and all i'd need would be a clutch & flywheel? this truck (k20- 'old blue') is a farm truck with a Hydrabed ( hauls 2 round bales of hay ). would like to have the automatic because of all the forward & reverse shifting moving hay, but i can deal with the 4 spd. don't want to put too much money in it.
nvrenuf
Mobile, Al.
What t-case is in the K30? Why not swap the th400/t-case assembly into the K20?
Yes, the 454 is a direct bolt up if you find a flywheel. you're clutch will work too but I'd swap in a new one since it'll be apart.
cpender
