350 tbi problem???
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
When the diagnostic circuit is fried, nothing will happen when you do the paper clip either. There’s not one single way those things can fail, however. It’s strange, though, that it’s doing that. It’s possible that the connector on the tool isn’t reaching serial data, diagnostic data, ground, or some combination of those. You’ve clearly got access to two of those so the fault could very well be with the serial data either on your end of the scan tool’s end. The only way I know to test this is with a homemade tool that only goes between serial data and ground or with another scan tool.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Oh, yeah. Definitely power. Completely overlooked that one. That’s like trying to make a cake without batter.
Vaughn
Colo Springs
Vaughn
c30
TBI systems are brutally simple, they aren't that hard to fix.
There are 4 things that directly affect the air fuel ratio. They are the O2 sensor, The CTS, the MAP sensor and fuel pressure.
So far, I haven't heard anyone talk about the MAP sensor, or making sure that the vacuum line going to it is connected right. If the ends of the vacuum line are brittle, cut them off so that they hold onto the MAP sensor - or just replace them with new. If this line is disconnected, the engine will run really rich.
Make sure the vacuum line to the PCV valve is connected, this will cause the engine to idle high and/or cause it to surge. Make sure that the hose to the brake booster is connected also and not cracked. Your engine has a bad vacuum leak, and the above items are the most likely culprits.
CTS - Domestic manufacturers use a temperature of about 200 degrees to determine when the engine goes into closed loop. To make sure of this, you should be using a thermostat of 195 degrees - lower temperature thermostats won't cause the ECM to go into closed loop. If the ECM isn't going into closed loop, the ECM won't read any data from the O2 sensor, and won't make changes to the fuel mixture.
You should check the fuel pressure. GM didn't read fuel pressure via a sensor on the TBI fuel injection systems, but they really should have, because it comes up a lot on TBI systems. The GM spec for tbi systems is 9-13psi. You will need an adapter to read it, like this:
https://www.ebay.com/itm/TBI-thrott...978587?hash=item3d26fad81b:g:US0AAOSwQItUJEQZ
The O2 sensor should be on the drivers side exhaust manifold at the back in the collector, except in certain applications. TBI systems only used one, and no O2 sensors after the cat.
A scanner probably won't help you until you fix the trouble codes and/or vacuum leaks. It doesn't help you to know things like the O2 crosscounts, if the system is running rich all the time.
This is a troubleshooting guide for TBI systems:
http://www.73-87chevytrucks.com/techinfo/TroubleshootingTBISystems.pdf
JOHN MEADOWS
tennessee
john
1/2 ton custom 4x4
350 tbi
I would like to thank everyone for their help in this matter ( well besides Rusty Nail since he only made jokes lol), After many nights trying to figure out the problem and never did , i posted my truck and its sold. It became for of a headache than anything. So now i must find me another one lol
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Well, that's one way to make a problem go away. Good luck with the search.
4WDKC
Southern Florida
Kacy
sucks that you couldnt spend the time to resolve the issue but understand the frustration.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Hmm, maybe the next guy can whip it. Hopefully they continue your efforts on the TBI rather than going the carb route. That doesn’t sit too well with me in many cases. I also understand the frustration, but I wish it would have worked out for you. Good luck with your hunt!
that_orange_c10
