33's in place of 31's?
78C10BigTen
pennsylvannia
C10 BIG TEN
Would anyone know if i could fit 33x12.50x15's on the rear of a stock 78 c10 big ten? It has 31x10.50x15 on it now but not much luck finding any used. Just curious if theyd fit up under the stock back end. I personally think they would as it sits pretty high out back. Thanks for input
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
They will fit... but I would be concerned about your rolling gear ratio. These tires will effectively raise your gear ratio. What rpm does is sit at on the highway?
78C10BigTen
pennsylvannia
C10 BIG TEN
Round about 2700 at about 75-80. Its a 3.08 rear
Bolt 'em on and show us pictarz!
Also, I ran my K5 with 33's and 3.08 gears for a while. It was a little sluggish off the line, but overall it was a decent combo for DD duty.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
No doubt, but your K5 is 4x4 so extra weight and gears and all... on a 2x we can generally get away with slightly higher gear ratios.
Yep, that's what I meant. Should be ok on a 2wd truck.
MADDOG54
