327???
73jimmy
seattle,wa
luis
jimmy
so lookin for a motor to throw in my jimmy to quickly get it back on the road and a friend of mine has a spare 327 that came out of a truck and was wondering if a 327 would work as a good permanent motor or would i have to think about a 350 down the road...so i guess my real question is whats the pros and cons to a 327 to a 350...is anyone running a 327?...thanks
If it's a large journal 327, it's a 350 block anyway. Only difference between a 327 and 350, and I do mean the ONLY differences is the crank, and the compression height on the pistons. Past that, identical motors. Same Con rods, push rods, heads, balancer and all. So if it's a 68-69 327 it's a 350 block. Run with it. It'll be a good running motor. Then when you rebuild it later on down the road, simply buy a 350 engine kit and find you a very easily commonly found 350 crank and put it together, now it's a 350.
If it's a 62-67 327, then it's the small journal 327 with a forged crank. Those motors love rpm and run forever and ever and ever and huhhhhhhhhhhhh ever and ever and ever. But, a 350 crank won't fit the small journal motor and the con rods do NOT interchange with the 350.
At any rate, either one of the 327's are good motors. So if it's a good running motor and runs good now, grab it and go with it. Nothing wrong with a good 327. 350 has a bit more torque and that's about the only difference. And being realistic, if it's a pre 69 motor, chances are it has more compression, hp/torque than say a 76-86 350 due to smogger heads and decammed motors for gubment emmisions. Rock with it is my suggestion.
73jimmy
seattle,wa
luis
jimmy
Thanks ..this really helps think I'll go with it then...and see how she runs in then jimmy
bobkyle2
Illinois
Kyle
K5 Blazer
Always loved those 327's.. They like to be revved to the moon.
:popcorn:
I like 327s. I can't find any around here, they are scarce these days.
junkyardog05
Tennessee
Keith
454/ 400 turbo/ NP203
HotRodPC is right 327 and 350 have the same bore on the cylinder (4 inch) just a shorter stroke on the 327. 327 is a good engine and hard to find around these parts.
Dons79C10
