205 tcase help!!!
Doug80
Chicago
Douglas
Ok my tcase is leaking at the front output I already found the one seal I would need that is round but I need to know part numbers and names for the second one. It pretty much looks like a carb gasket that goes between the carb and the intake. Any info/help would be greatly appreciated.
MadOgre
NA
NA
NA
NA
NA
You can use a sheet of gasket material and use a small hammer to gently tap the imprint of the mating surface into the gasket material. Just keep tapping with the hammer and it will cut the gasket on the edge of the mating surface. You will end up with a perfectly matched gasket. Use a ball peen hammer to get the bolt holes.
I did this for my 4x4 adapter and it has never leaked.
highdesertrange
kalifornia
mike
k30
why are you pulling the flange? leave the flange in place and just replace the seal. highdesertranger
Doug80
Chicago
Douglas
Ok guys I got the gaskets and everything I need but I was wondering what is the tq for the nut that is on the shaft coming out of the tcase that holds the flange the driveshaft bolts to? Having issues finding it?
JOD26
