2 WD to 4 WD swap
Michael
Erie pa
Michael
Scottsdale c10
Need help on a swap I have a 2 WD 84 Scottsdale I want to swap to a 4 WD and my friend is giving me the tranny the case and all the axles for cheap I have control arms up front now I know I take those out but will my axle bolt right up to the front end with no problems and then I ddrop my tranny out and bolt up the new one with case then the back will bolt right up to put the axles in is it that easy as it seems or is it hard I'm not frame swapping so don't even tell me about it
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Its a lot more involved than everything just bolting up.
Georgeb
Wisconsin
George
K10 Burb Z71
Without listing off the massive amout of things you need to do to make this swap I will say you would be better off finding a 4x4 truck or frame and swap the body. You will be money and time ahead in the end. I'm not saying it can't be done but It's not worth it.
highdesertrange
kalifornia
mike
k30
you said you didn't want to hear it but a frame swap is much easier. highdesertranger
Michael
Erie pa
Michael
Scottsdale c10
I pretty much figured it out now thanks tho guys
DAT_141
