2" Rear Block Removal
buRRp
Grand Forks ND
Lee
V2500 Suburban
I am looking at removing my 2" rear blocks and putting on ORD Shackle Flip kit. My question is will I only need the 2 1/2" kit to make up for the blocks. Part # for the kit is GU38012. I all ready have the Offset 1" Zero Rate Add a Leaves from ORD. Still new at this kind of stuff so I just want to do it right.
Also when I bought the Burb the previous owner already had the Rough Country 6" lift for it and never installed it. I have been reading on here that Rough county kits are just that. Was thinking of swapping out the front leafs for some different ones. What does everyone suggest?
Thanks for thr help. :High 5:
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I suggest you sell me the 6 inch and do the 4 inch shackles. You get half the lift for what the shackles are so for 2 inch shackles you get 1 inch and 4 you get 2
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
This is true for longer front shackles, but not the rear shackle flip. In the stock position with stock shackle the rear of your leaf is ~4" above the bottom of the frame. When you flip it it is then 4" below the frame, 8" total /2 = 4" lift. Their 6" Super Shackles net about 5" of lift but you would be better off to use 2" lift springs with the 4" flip kit, or a 2" block if you're wanting 6" lift. On their site they explain the 6" Super Shackles in conjunction with the 4" flip bracket yield too much pinion roll and have a weird feeling of instability.
buRRp
Grand Forks ND
Lee
V2500 Suburban
Thanks for the help guys.
smurph20
Brad
cool atleast i was half right lol
85Shortsquare
