1995 Suburban Family Battlewagon
Catbox
Peter
C20 Silverado Camper Special
I forgot to mention, pre new cat it was a 330ppm at idle kind of stinker.
Now it is down to 39 with nothing else to help emissions.
So I believe the cat is a good thing to have in there to clean up the exhaust.
The exhaust note is still plenty noisy for a compliant vehicle.
Catbox
Peter
Just dropped $1000 on parts to get this thing making cool air again.
As well as several other little things that needed to be replaced.
Like the radiator......again.
This will be the 4th radiator I have put into this thing since I have owned it over the last 19 years.
Hopefully this time it will last more than a handful of years.
I sprung for the fancy full aluminum one, no more plastic tanks.
Catbox
Peter
I do like the fact that RockAuto.com offers kits for large projects where it makes sense to do all the parts together.
Here is the A/C kit that I bought for it.
It includes all this stuff and they tell you what else you will need to complete the project at the bottom of the list. I find that super helpful.
The refreshed rear is all done once again!
To the tune of $1148 this time.
Now to get over and pick it up so the reinstallation fun can begin.
@Maxwellvis has it in his head that he wants to install a set of 3/4 ton rear leaf springs under it.
The reasoning being it will give the rear a modest 1.5 to 2 inch lift.
Then we can turn the front torsion bars up to match in the front.
That's a great deal. I just lost the rear spiders in my '07 Tahoe Gov Bomb unit and I was thinking of going with that Trutrac, glad I didn't!!!!! I went with the Auburn L/S. I got whacked for $2500 clams but you saved a bit on labor there. I didn't have time to dick around with it slaving away at 70 hours a week at work. And I'm getting old and fat and tired of laying on my back on the ground too lol.
Catbox
Peter
Luckily I have a 19 year old that loves a chance to wrench on a car.
I am happy to finance the projects when he wants to do the work for me.
You a lucky man. I have 2 girls. One was my little hard core wrenching buddy until she turned 18 and got married and took off on me.
Catbox
Peter
Here is a video of the cold start weirdness that the Sub has done randomly for the last couple of years....
There are some sharp TBI brains in here and I am not sure what to look at to fix this issue. Luckily Max recognized the issue this morning when he went to take his sister to school and called me out to have a look at it.
After the issue clears up at around 45 seconds of idling like it has a hot rod cam in it, it takes off and runs just fine. No miss, no bog, hitting on all 8 like nothing ever happened....
Catbox
Peter
We changed out the cheap coolant temp sensor for an new original Delco part.
Then Max checked to see if it was throwing a code.
Yup.
Code 33....
He removed the air cleaner and sure enough the vacuum line to the MAP sensor had popped off the nipple.
Reinstalled it and all issues were gone.
I ordered a kit from Amazon that has several sizes of silicone vac hose in it as well as new clamps and stuff.
We will be replacing all the vac lines on the engine as they all most likely have 230k miles on them.
It has been back up and running like clockwork since the fix the other day.
Ta1nt3d
