1990 Suburban Master Cylinder Upgrade
dag4566
Suburban
Have an LS swapped V1500 1990 suburban and just trying to do some upgrades as I work on it.
I have new pads, rotors, and drums/shoes and the pedal is a little squishy then gets hard. I bled out some nasty fluid and it improved slightly but I am wondering if there is a possible GM part upgrade. I have researched and found a 99-2000 master may be the ticket, just need some guidance. I have these options, just need to know what I should order to upgrade. Any help would be appreciated.
Thanks,
Z82Heavy-duty trailering package
Z83Heavy-duty chassis package
Z85Heavy-duty suspension
Newer master cylinders are designed for low drag calipers,the bore designs are changed.
dag4566
Suburban
Mine has the 90-91 plastic resivior and ABS if that makes a difference
nvrenuf
Mobile, Al.
@dag4566 i have a 91 Blazer and I’m using a 99 C3500 m/c (for 4 wheel disc) on my original vacuum booster.
I wouldn't change anything until I figured out why my OE stuff wasn't working right. Your pedal shouldn't be squishy and then get hard. Have you adjusted or checked adjustment on your rear brakes that's a biggie a lot of people don't think about.
Keith Seymore
Motor City
Keith Seymore
4.3L
Thanks,
Z82/83/85 have nothing to do with brakes.
K
dag4566
Suburban
I read that trailer packages changed drum size.
nvrenuf
Mobile, Al.
@Keith Seymore do certain rpo’s like the trailer pkg trigger the inclusion of others like the bigger brake rpo’s?
Keith Seymore
Motor City
Keith Seymore
4.3L
No.
You can see from the chart above that the only thing that drives the specific parts is the brake system RPO.
K
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
My C10 is a GMT800 Tahoe master with an S10 reservoir.
Has rear discs on a Ford 9.75 axle.
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
I just want to swap the plastic reservoir over aluminum stock 85 mc for an all metal mc… 1.25” rotors with 11+” rear drums… Worked just fine, looks like a shaved down dirty dog’s butt… Truck is going full lowrider with 60s/70s style underhood trimming, yes that means chromed alt-ps-pb components, braided stainless hoses/lines, ribbed cast aluminum valve covers/aircleaner… Plastic has to go away.
cyclic
Ft Hood
James
Suburban
Take a good look at my old thread 88 Burb complete brake upgrade
Most of the pics are gone, but the info is good and very on point for 1/2 ton square bodies.
duncan_schawalder
