1990 r3500 won't start
87silveradok20
Ohio
Levi
Silverado k20
Ok so I have a 1990 r3500 western hauler. It had a fuel tank in the bed that was cracked. I took the fuel tank out and plugged the lines and now it won't start. If you pour fuel in the throttle body it will fire. So can anybody help me
MadOgre
NA
NA
NA
NA
NA
It wont start if you don't have a fuel tank
87silveradok20
Ohio
Levi
Silverado k20
It has two and I only removed one. The one it has has fuel in it @MadOgre
87ChevyR10
Kansas
NA
NA
NA
IS there some sort of tank switch like on other dual tank trucks?
MadOgre
NA
NA
NA
NA
NA
Well Im thinking if you had a fuel tank in the box that the other saddle tanks were in operable or disconnected ?
87silveradok20
Ohio
Levi
Silverado k20
I got it. There was dirt in the filter
87silveradok20
Ohio
Levi
Silverado k20
Yeah actually there are lines that run to the original tank selector valve. And the pump wires are extended up to it.
Obullard74
