1988 TBI Stalling
1988 one ton
Baton Rouge
Dennis
C30
Ok guys i'm new to this site. I just bought a 1988 Chevy C30 with a 350 TBI in it. My problem is stalling and shutting off when i give it gas.
Welcome aboard. Try plugging the line to the EGR valve and see if it runs better.
1988 one ton
Baton Rouge
Dennis
C30
I tried that and still no change. I was wondering, can it be a timing issue?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
How does it idle, is it smooth?
Is the check engine light on?
I would start with a new fuel filter, based on the symptom.
Timing would have to be waaaayyyy off to kill it.
1988 one ton
Baton Rouge
Dennis
C30
It idles smooth and i replaced my fuel filter and both temp switches today. Still no improvements. My check engine light came on today when i cranked it up.
Jims86
Patterson,Ca
5.7 TBI
Are you familiar with grounding A and B on the diagnostic connector to retrieve codes?
Do you have any modifications?
You may neednto spring for a fuel pressure tester, unless they rent them out at the parts store.
1988 one ton
Baton Rouge
Dennis
C30
Ok, after changing the fuel pump, fuel filter, and both coolant switches, oh yes i almost forgot the freshly rebuilt throttle body i got a wild hair and changed my map sensor and the problem is solved. Thanks for all of the input.
Jims86
Patterson,Ca
5.7 TBI
Cool....I wish we knew which it was! LOL!
it was either the pump, or the MAP sensor.
thinchey
