1988 241C non VSS. Is there a conversion kit to make it VSS??
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I got a 241 with a mechanical speedo {1988} model. I need a vss for a LS swap. 6.0 4l80e.
What are my options? sell this one and find a 90/91 with vss. Anyone know of a conversion? thanks
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Dakota Digital VSS generator with pass through. Part # SEN-01-4160
Plugs in between your existing speedo cable and speedo output on the tcase. Will allow you to run your existing gauge and generate a VSS output signal for the PCM. You will need to let the tuner know of what pulse the adapter is generating since its different than what the PCM is looking for.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Thanks crispy. Im also running the Dakota Digital HDX cluster. They plug right into your ECM:cheers:
SquareRoot
My Dakota Digital is the cats ass! Just plugged it into my Edelbrock Pro-Flo 4 and I have every engine parameter at my fingertips. Good stuff.
orpheus
