1987 Chevy 5.7L TBI Fuel Issues
bbush44
Nebraska
Hello,
I have a 1987 Chevy, half-ton, 4x4, with 5.7L TBI engine. I have owned the truck since 2000, and it has been my work, hunt, fun vehicle. About 5 years ago, the steering gear had such a bad leak I parked it until I had time to replace it. Well life has slowed down a bit, and I am getting it back on the road. I replaced the steering gear so that problem is solved.
Next problem, while it sat the passenger side tank rusted through and leaks. I never put a lot of miles on the truck so don't really need dual tanks. I removed the passenger side tank and plugged the lines at the cross over switch. When I put a battery in the truck, and turned the key I do not hear the fuel pump build up pressure in the driver side tank. I checked connections and fuses and all was good. I ran 12v directly to the pump, and still nothing.
I dropped the driver side tank, and it appears the fuel pump rotted away the years it sat. I found an aftermarket fuel pump and replaced it. I also replaced the fuel filter while I was at it.
I put the battery back in, and turn the key still nothing from the fuel pump. I check connections and fuses again, and all is good. When I turn it over there is no fuel at the throttle body. If I spray fuel in the throttle body the engine will run until the fuel is gone.
Did I get a bad aftermarket fuel pump?
Is there something I can check to confirm this or not?
Any other suggestions? I am stumped.
Thank you in advance.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
First thing I'd try is running 12v to the red test lead on the firewall next to the FP relay. If the pump runs, then you potentially have a bad relay, or issues with the wiring to the pump. Also, a silly question, what position is the Fuel Tank selector switch at in the cab? Make sure it's on the correct tank.
bbush44
Nebraska
Thanks foamypirate, I will need to try running 12v to the test lead on the firewall. Just 12V right from the battery, does the key need to be on, etc?
Not a silly question, but yes it is on the correct tank.
Thanks
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Thanks
12V straight from the battery will do the trick, no need for the ignition to be on. That lead is a straight connection to the 12v+ side of the fuel pump.
bbush44
Nebraska
Thanks Foamypirate, I will give that a try this weekend when I am back home.
bbush44
Nebraska
As an eBay Associate we earn from qualifying purchases.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I didn't get as much time this weekend as I planned to look into this issue, but I did run 12V to the test lead, and they pump did not run.
So where do I go from here?
Check the connections at the pump?
Any other connections to check?
Has anyone ever had a aftermarket fuel pump show up bad?
This is the pump I purchased.
http://www.ebay.com/itm/191000689964?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Thanks in advance.
The aftermarket pumps have a pretty spotty reputation. First thing to check though would be the wiring. There are grounds from the sending unit to the frame. I can't remembe if they tie into the pump or just the fuel gauge circuit, but probably not a bad idea to check and make sure they are solid. From there, I would check the 12v+ wiring. You should be able to disconnect the plug going to each pump and check the brown or gray wire (depending on the side) for 12v+ when you have the battery hooked to the test lead on the firewall. If you still don't have 12v+, you have a wiring issue. If you DO have 12v+, you either have a bad pump or a bad jumper harness.
If it ends up being a bad pump, I'd go with a new ACDelco from RockAuto. I've been running two of them (one in each tank) for about 2 years now without issue. They really aren't terribly expensive for the peace of mind.
cbob64
