1984 K10 Pressure PS Line Part #?
AlexK10
Puerto Rico
Alex
K10 Long Bed
Hi everyone, I have a 1984 K10 and have run out of luck finding the correct PS pressure hose.
The hose I took off has an o-ring end on the pump side (correct) and a flare on the steering box side (??).
The new hose part #71088 from autozone has all the right bends but both ends are o-ring seals. And I have no way of connecting in to the steering box.
This is a 305 K10 with the saginaw pump.
Any idea what is the correct hose part number that has an o-ring seal on the pump side and a flare seal on the steering box?
Thanks
dvdswan
Port Orchard, WA
Dave
Do you have a picture of both hoses?
And dare I say... did the autozone parts person look at the right make, model, year, engine code?
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Maybe the gear has been replaced by nd older gear? May have to have a new one "built" by a good shop or parts house?
Moderator
Yep. The gearbox should have the o-ring style on an '84. The options are either swap out the box, have a hose made, or run an SAE-to-metric adapter.
AlexK10
Puerto Rico
Alex
K10 Long Bed
Thanks, I saw the adapters that would convert the oring seal to flare (see attached image).
I also tried removing that flare thing with some needle nose pliers from the steering box thinking someone had added that adapter in there and the steering box was actualy a 1984 oring style, but no. The flare didn't come out.
I would need the opposite, an adapter that would change the male flare on the steering/gear box to receive the oring hose end.
Does anyone know if these adapters exist? flare to oring? SAE to metric?
Moderator
I've seen the adapters before, they thread in. Another thought, you can also change the fitting on the pump and run a hose for an older truck.
AlexK10
Puerto Rico
Alex
K10 Long Bed
Thanks Bucket, I would like to keep it as simple as possible, with an adapter on the box and the new o-ring hose that I already have.
All I need is to identify which fitting I need to make that connection and be done with it.
Its a beater truck I'd like to keep running for hauling stuff but don't want to spend time messing with it if I don't have to.
AlexK10
Puerto Rico
Alex
K10 Long Bed
I just found these on eBay. Seems they could be the correct thread sizes, need to confirm that later today with my caliper and thread gauges.
AlexK10
Puerto Rico
Alex
K10 Long Bed
This is what Im trying to adapt, Old=Flare New=Oring
Moderator
Those should do the trick.
MRmolash
