1983 chevy k30 dually width
81dually
cazenovia ny
matt
gmc 3500
im curois what the outside of wheel to wheel on the rear of a 1983 chevy k30 dually is? and how to make sure its not a cab and chassis truck?
fast 99
Spokane, Washington
Without measuring inspect the distance between brake backing plate and rear spring pack. If there is only an 1' or so cab and chassis, 6" will be a pickup. Reason, inner dual tire clearance for pickup bed wheelhouse.
legopnuematic
Licensed Junk Dealer
MO
Spencer
A cab and chassis will use a 14 bolt axle, a dually pickup uses a Dana 70HD rear axle.
The shape of the covers will give it away, along with the Dana will only have 10 cover bolts.
81dually
cazenovia ny
matt
gmc 3500
can anyone tell me if this is a cab and chassis truck? it has 8 bolt wheels
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Cab and chassis meaning a truck that was converted to dually?
nvrenuf
Mobile, Al.
No, a C&C is a truck with no bed from the factory. Fleet type sales trucks that might get wrecker or tool body beds, etc this is why the rear axle is narrower than a pick up dually. These can come in various wheelbases longer than a typical long bed pick up and the frame is shaped differently.
nvrenuf
Mobile, Al.
Overall width can vary based on tire size. A cab & chassis axle is 63” from wheel mounting surface to wheel mounting surface, a pick up dually is 74”.
Pickup wheelbase is 131.5" while the typical cab and chassis wheelbase is 135.5" long.
guitarplayerdan
