1982 c10 Driveshaft
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Ok guys I found out m driveshaft is bent hopefully that is the reason im breaking bellhousings. Anyone know the length for a 82 c10 longbed with th350 with long tailhousing with a 10 bolt rear?
Why not measure the one you have already? If it's bent, I'd think it would cause a vibration rather than breaking bellhousings.
How are your engine/trans mounts? Checked the frame for excessive flex from broken rivets, loose bolts, or cracks in the rails?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Saw your post on FB Joey and meant to post there.
It SHOULD be 69 33/64".
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Just was seeing if someone had it off hand! And I've got prothane motor mountd I've tried stock rubber and poly trans mount. I had a broken leak the main leaf actually I thought that was the problem but when I went to the strip it broke. I know my frame is tweaked some about where the frame steps up for the bed but don't see how it would cause it
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Thanks retro!
82chevy350
Van Buren, AR
Joey
C10, K10, K5
And everything is tight no loose rivets I broke 3 bellhousings and finally just ordered a ultra bell.
What kind of times do you run?
82chevy350
Van Buren, AR
Joey
C10, K10, K5
Bad a 16.75 1/4 mile didn't get to tune or nothin got one run :/ its a all stock motor just wanted to run and race "legally" lol
aaron06
