1981 Jimmy grille options
swbchevy
AL
c 10
I have a 1981 Jimmy 2wd, with an aluminum billit grille. What are the options for installing an original style grille? Maybe a 1985 gmc grille? Thanks
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
You could, and I think the 85-88 GMC grille is the best looking, but I guess I'm biased. Those have recesses in them, though, for the semi-hidden park lights/turn signal lights. Do you want to do that, too, or just keep them in the bumper? As far as options go, you could do an 81-82, 83-84, 85-88, and 89-91. All but the latter will just bolt in. The 89-91 requires a different core support.
swbchevy
AL
c 10
The park lights have already been moved to the core support. The previous owner did that when the aluminum grill was installed. I have changed the headlight bezels(dual lights) to 85 model. I prefer the 85 grille also.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Well, if the actual park light assembly is the correct one, I'd go for it. If not, I'd go to the junkyard or eBay, find two to put in there, and then go for it.
swbchevy
AL
c 10
I agree, the stock grille needs the correct lights. thanks
K10noob182
