1976 wiper motor
Shula
wa
chad
Everywhere I have looked, the wiper motor for my truck is no longer being made. Local junk yards have none. Anybody know where or who makes on that will fit?
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
Not many choices. NAPA lists a reman, part # RAY 49-160 $142 + core.....Autozone lists a Cardone reman part#40-160 $73+ core. Possible that @SirRobyn0 may know of a good outlet for one??? May be better off trying to rebuild it? See @Doppleganger for info?
84-C20
Chevrolet
No not many choices. For the 80's models there is a Wia brand - new unit available though autozone and online at places like amazon. For the 70's trucks, as far as I can tell the only company making wiper motors for them cardone poor quality reman. The Napa Ray units are also remaned by cardone.
So your choices are, finding a good used unit. Rebuilding it yourself, installing a later model wiper motor or purchasing a reman cardone. If you decide to go with the cardone hopefully you'll get lucky but don't be surprised if you end up putting in a few of them before you get one that's good, they are that bad....
Shula
wa
chad
Will a later model unit bolt in like the original, or will there be modifications that I will need to do?
Shula
wa
chad
Great thanks! I will definitely look into that, probably next week after my son’s graduation. I appreciate the guidance, this will be my daughters truck in 6 mos when she turns 16, which gives me an excuse to find a k20.
Thanks again
84-C20
Chevrolet
Yes. I think there is just some modding with the wiring (washer switch).
This is correct to the best of my knowledge as well. And if you get for example an 84' you'll get a mechanical washer pump like your current one has. If you get an 85 on up, you'll need to add an external electric pump for the washer, but you'll actually get a better system, it's just a little more work.
petrified_peach
KCMO
Megan
Adding for everyone else with this issue who hates rewiring and just wants things to work right , 40-162 will also work. My ‘73 wiper motor just **** the bed and it’s been a struggle trying to figure this out since nobody sells 40-160 under $280 online. I saw 40-162 on eBay and it looked exactly the same so I took a chance, and it works! Same pins, same bolt holes. Hopefully this helps someone else down the line
ali_c20
Austria
Alexander
C20, K5
Does the newer wiper motor work with the 73 crank arm ? The different motors have different wiper motor crank arms.
that_orange_c10
