1973 Engine harness
mrstrick1
Mississippi
Michael
I have a 73 k10 that the engine harness has been hacked up. My first question is which wire coming out of the firewall goes to the oil sender? I have seen a diagram that said it was a blue wire. But I don't have a blue wire. I'll make a pic of the connection and see if anyone can identify some of the stray wires.
'73-'77 had a mechanical oil pressure gauge. There should be a copper/brass tube that screws into the block near the distributor, then winds around a couple times before passing through a grommet in the firewall and then goes to the back of the cluster.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
78's had mechanical gauge to, or atleast on the tach dashes
mrstrick1
Mississippi
Michael
pulled the dash and the line to the gauge is not there, now I just got to find one.
mrstrick1
Mississippi
Michael
can anyone identify the 2 small brown wires that are side by side at the bottom left and the black wire at the top with a fuse holder attached to it?
SlickGTP
Houston, TX
Interestingly enough, it looks like the junction block is on it's side... I'd take pictures of mine, but the truck is parked in such a way I can't get under the hood right now.
I just noticed that LMC Truck now sells the oil pressure tube for less than 20 bucks.
towjoe
Lafayette,IN
joe
K30's or V3500's
I just pulled a complete harness out of a 76 C10 I'll dig it out and see if I can figure it out. From looks of your picture looks to be on the taillight harness. It's the flattest connector of the 3 that go in fuse box. There's not much to electrical system of the 70's trucks compared to the mid 80's
mrstrick1
Mississippi
Michael
Everything works, except the amp gauge. could be wires for the old ac that is long gone. lights work perfect.
twitch1989
