1931 Chevrolet 2 door sedan (I think)
Is this worth buying?
  • Yes
    Votes: 7 87.5%
  • No
    Votes: 1 12.5%
  • Total voters
    8
  • Poll closed .
Preston
Mechanicsville VA
Preston
I know it’s a 31 not sure of the proper name there were different terminology back then. My wife and I went and looked at this yesterday not sure if I want to take on such a project. Anyway what is a post without pictures
Moderator
Pretty cool, but I couldn't tell you a single thing about it. My grandpa had a '31 as his first car, that's all I know, lol.
@Termite_Delight might have some input.
78C10BigTen
pennsylvannia
C10 BIG TEN
Thats cool!! Id make it run and just cruise it as is. Depends on the $$$. Id hop up that 6 and make it a sleeper.
Preston
Mechanicsville VA
Preston
He has a starting price at $4,000. Or trade me for my 66 Falcon, seems like his younger brother’s first car was the same model.
75Monza
Colville, Washington
K30, K20, K20
Depending on how much of the body looks like the under radiator support swiss cheese, that seems like a reasonable price to me. I've been trying to find a 29 Model A pickup for my dad for a few years and similar shape ones are around $6k in Washington and Oregon.
Preston
Mechanicsville VA
Preston
Yes seems like a lot for something that has been setting 59 yrs in a barn
Termite_Delight
Lanark Ontario Canada
K2500
5.3 L33, 4l80e, NP241c
Yes, It's a 1931 Chevrolet 2dr coach. The hardest part on these cars to restore is the wood, check the hinge pillars where they meet the header. The roof structure looks intact.
Moderator
I'm guessing that the two hoses stuck together are supposed to go to those tubes on the firewall? I'm assuming that's a heater core. Did they even have water heat in '31?
And what's that hose/cable under the dash, coming up from the floor? It looks like it has a button or something on the end of it?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Maybe a momentary switch for a starter?
I see what looks like a keyhole for a hand crank but...
Termite_Delight
K2500
The 4 cyl had an exhaust manifold heaters. starting in 1929 Chevrolet came out with the first 6cyl with an option for a water heater.
The cable from the floor is the ignition switch. It has a cable inside that attaches to the distributor, when in the off position it holds the points apart. Starter button is on the floor
78C10BigTen
pennsylvannia
C10 BIG TEN
Your a very knowledgable guy!
Termite_Delight
K2500
I've had many of these old cars, you get to know them inside out.
Better than the fords...
Chev had 4 leaf springs, f@rds had 2
Chev had a fuel pump with gastank in the back, f@rds were gravity fed, gastank behind dash
Chev were 6cyl valve in head, f@rds were 4cyl flathead
Why wouldn't you buy a Chevrolet?
GRat
