17 inch wheels
Logan2500
Waterman illinois
Logan
360/th400/np205
Im thinking of buying a set of bfg km2s they r 305/70/17 and with those i want to buy a set of mickey thompson 17x9 wheels with a 0 offset and a 5 inch backspacing. I know they will fit what im wondering is if the wheels and tires will look good on a 77 k20 with 4inches of lift. I tried the tires on my truck with a dodge stock wheel and the offset made the tires sunk too far into the wheel well. If anyone has put this size on a truck like mine if u have pics would be much apprieciated.
Italianwagon
Washington
Steve
V20 Suburban
How’s this turn out? Looking at the same
77 K20
Montana
K20 5" lift
HT383 fuel injected
Doubt you will hear back- that was a post from 9 years ago and the poster hasn't been back in 8 years.
Although the wheels would probably fit I'd think it is better to stick to roughly around 4" of backspacing.
Italianwagon
Washington
Steve
V20 Suburban
Trying to decide on these wheels 17x9. O offset-5 back spacing. Just trying to determine they’ll fit.
Must missed that dating on the post as I searxhe
77 K20
Montana
K20 5" lift
HT383 fuel injected
The closest wheel I can think of for you to compare is the old Hummer H2 wheels.
They were 17x8.5 and had a 5.5" backspace. I've seen several run those on squarebodies.
:shrug:
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
OP has pictures in his gallery which appear to already have the wheels mounted. Could use a little offset, IMO they stick out a little far and something looks off to me, but that's just me. (hah could just be that he never put the side mouldings back on after paint, to me that always produces a weird "somethin ain't right" look with that kind of two tone) See for yourself and decide if you think it's the look you're going for
seattlesquare
