15'' rim on 14bolt
82k20
westmoreland tn
jerry barnard
k20
350 modified
okay guys ive got a question about 15'' rims on a 14bolt. i was given a set of 15'' ''saw blade rims'' that have brand new dakota definity tires my k20 needs rims and tires so my question is can i make these rims fit the k20 what kind of mods will i have to do now my 14 bolts are 8 lug and my rims are 6 lug any ideas on a spacer that would work or do i need to swap out axle shafts my uncle passed away and my aunt gave me the rims i would love to use them on the k20 mainly because he was the one that started me on cars. any help would be appreciated.
Konas new ride
Alberta
Gerald
If your 14 bolt is a full floater will a spacer clear the hub? Also will a spacer space it out far enough for the rim to clear the brake drum? I would measure the inside of the rim and the diameter of the brake drum..
82k20
westmoreland tn
jerry barnard
k20
350 modified
ive been doing a bit of searching and i have not been able to find a 6 lug 14 bolt around here. Mine has a 14 bolt sf front and rear. ive been told that the spacer idea is a bad one i was told they arent very durable
It would be a 10 bolt front.
Spacers really aren't bad, but the adapters you are thinking of usually are a bad idea. You will just need to get 8-lug rims.
82k20
westmoreland tn
jerry barnard
k20
350 modified
yeah that was my bad bucket i got in a hurry and miscounted it is a 10 bolt front did they ever offer a 14 bolt front
Nope, there was the 10 bolt, the Dana 44, and then the Dana 60 was used in 1 tons.
82k20
westmoreland tn
jerry barnard
k20
350 modified
thanks bucket as yall can tell im still learning about auto repair
Squarebody322
