14 SF 6-lug Axle for 73-87, what is the best option
Mattchu60
Iowa
Hi All,
I have been planning to swap in a semi-float 14 bolt 6-lug axle. I thought that some K20's came with this axle in 6-lug version, but it seems I was wrong. I looked at a K20 once that had 6 lug wheels which is why I thought they existed, I wonder now if it was a K10 with k20 Badges on it.
I would really like to keep my 6 lug wheels, as the tires are almost new, but I need more strength than the 10-bolt rear can offer. This is a work truck that will have heavy loads on it from time to time.
Is my only option to go with the 88-98 SF rear from a Z-71 4x4?
I understand that the perches need to be removed and rewelded. What about the brakes? Are they drums or disc? I dont need disc brakes if they are drums.
If anyone has done this swap and can give me information on how to perform it, that would be great. I had done a lot of reading and there is some conflicting/blurry info out there.
Thanks
Stroked
Beloit, Kansas
Jared
I think they only came on the "light duty" 3/4 ton's. 2wd or 4wd.
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
Mattchu60
Iowa
My understanding is that the light-duty 3/4 ton K20's all got 8 bolt Semi-floating axles, not 6 bolts. Is that correct?
Stroked
Beloit, Kansas
Jared
I don't know if there ever was a light duty K20. But yes, the K20 and C20 from 81-87(I believe) got an 8 lug, semi floating 14 bolt. I don't know this for a 100% without a doubt fact, just stating my observations.
I'm talking about the 88-98 body style. You could get a light duty 2500 that had 6 bolt wheels. It had the 6 lug, semi floating 14 bolt.
Kapdin
North Dakota
Lance
yea we had 2 on the farm. a 1989 chevy light 2500 and a 91 gmc 2500 light and both had the 6 lug.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
88+ the 7200# gvwr 2500s got a 14SF, and the 8600#gvwr got an 8 lug 14SF, with a FF as an option. also keep in mind that the 2wd 6 lug 14SF is about 3"narrower. IIRC, the gvwr thing is the same on squares and the SF or FF rear axle.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Also, the 6 lug 1/2 ton "Z71" 14 bolt is not a Z71 deal, it's option code F44 (heavy duty chassis). This option is NOT a part of the Z71 package. The Z71 package is shocks, skid plates, and bedside stickers.
However, I have seen some weird combinations, such as F44 trucks with the 10 bolt and an 80e (which wasn't available in anything under 8600#) to a non F44, non Z71 K1500, purchased new by a depends mother in 94 with a factory 80e and 14SF.
TRokk
Randle
Jeff
350 5.7 V8
Guys, I have a 3/4 ton back axle, 14b, 8lug with 3.73 gear ratio, on a 79 GMC High Sierra Jimmy however a 1/2 ton front axle with 8lug with a 10b GM Corporate Axles
Jake_S
Charlotte, NC
350/SM465/NP208
The square 3/4 tons came with either a 14FF or 14SF (depending on the year and options), D44/Corp 10 bolt (depending on year of vehicle) and all are 8 lugs.
As stated above the 6 lug 14SF came in various 88-98 models, and I believe they are all drum brake units.
Jake
boarder421
