1 piece drive shaft in a 3+3 dually??
lowNslow
Jonesboro Ar
Nickalous
c30
Is it possible?? Goin to be running a 4l80e out of a 2004 2500 HD
Kapdin
North Dakota
Lance
1977,1979,1984,1987,1988
Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
I 2nd this question.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Your best bet would to estimate the length needed (add or subtract the different between your current trans and a 4L80E), and then take that to a driveshaft shop and ask if they think it can be safely built.
I'd sure think not. That's an awful long driveshaft. Why would you want a single? What's the purpose? Not only is the length long, but what about if you're carrying a load? The truck squats to much it might just end up on top of the driveshaft. I'd want a dual at least.
John-e Bravada
Oregon IL
C30 3+3
5.9L CTD
No, it's too long for a straight run, Spicer has calculators for max lengths for each joint a tube size. Once you get over a certin length the tube actually droops in the middle and it's impossible to balance, it just whips.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
If it was possible, don't you think GM would have used them to save cost? I'm with everyone else It's to long a run and will be weak and hard to balance
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
You could make your own and make a completely solid driveshaft!!! Not cost effective...
I agree: If GM did it from the factory, there was a reason. Iv never seen anything longer than an ext. cab short bed without a 2 piece in it, if that makes sense
My reasoning for the multi-piece drive shaft would be if you did put a load on it, or even hit a big enough bump, youd think itd pull out of/ram into the transmission since it has zero play in it
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
1-piece shaft works just fine in this situation. The output shaft is splined, so the driveshaft can slide in/out of the transmission as the susepnsion is loaded/unloaded over bumps and dips or from carrying a load.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
On a crew cab long bed?
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
But youd think on a crew cab long bed the travel would be exaggerated by the time it reached the front of the mile long drive shaft. I could be wrong
Yeah well first off, quit exaggerating. Not sure where you come up with a mile long driveshaft. It's more like a 1/4 mile long sooooo.... just sayin' :shrug:
:laughing1:
Bottom line, I'd just go 2 piece for several reasons.
Green79Scottsdale
G.R. - MI
Bob
Actually, mechanically speaking, I would think a longer trans to diff length would reduce the amount of play in the slip yoke. Kind of like backing up a trailer. The longer the trailer, the less your steering inputs translate to trailer movement.
There are enough opinions in here, mine is null and void.
lowNslow
Jonesboro Ar
Nickalous
c30
It was a thought.. i know the 4l80e is a lot longer than the turbo 400 that's in the truck.. so just wondered if it was possible
Your opinion isn't null and void. I get your point and agree, BUT, in this case, this driveshaft would be to long. What he needs to do if converting from a Th400 to a 4L80-E is simply take the driveshaft, both pieces, to a driveline shop and have them cut the front shaft to fit the 4L80-E and just because, I'd have both pieces balanced as a single unit and new U Joints and carrier bearing while it was out.
Todd Lemon
