Sbc 350 vacuum hose help
SDTECH1
DFW TEXAS
Ron
350ci, 4-speed
Original hydroboost brakes. No vacuum needed. I’ve never seen any traditional booster on a diesel either.
Mines leaking a little and I should probably rebuild/replace it soon.
Yep, and you probably never will see a vacuum booster on a diesel equipped unit.
Not unless that diesel has an external vacuum pump.
JBswth
Vallejo, California
James
C25
292 cubic inches
You can't use a conventional booster on a diesel - diesel engines don't generate enough vacuum.
J. B.
Truck82
Alderton
Christopher
J. B.
It’ll only work with an external vacuum pump like @SDTECH1 said.
grego28
