Smoking Ground Wire
454_SquarED
South FL
Ed
My 87 running like a top after a new Coolant Temp Sensor and TV cable adjustment. Just when I say to myself, Self...this thing is running goooooood, I put my left blinker on, get into the left turn lane, after sitting for about 10 seconds waiting for traffic to clear the truck dies. Try to restart and there is barely enough power to turn the starter...smoke coming from the hood and i see this (Pic attached).
What in the holy name of Square Body demons caused this? Some funky ground thing? I've only had the truck for a couple weeks but its been fine up to this point.
The only thing on was the blinker trying to make the left. Every time i tried to start it that wire would start burning. Tried again and started and ran fine...ONLY THING DIFFERENT is I turned off the blinker. Drove it home like a BMW owner (Not using the blinker) and no problems. I suspect some short with the blinker circuit. I noticed the voltage gauge clocks back and forth while the blinker is on. I am assuming when the blinker is on that small wire is carrying the load of the starter but I'll be damned if I can figure out why when its got a big 2 guage wire sitting right next to it grounded nicely.
Ohm meter shows little to no resistance across the burnt wire to its grounding point.
Any ideas?
Any ideas?
you need to shore up the grounds. Heads to the firewall. frame to core support. Engine to battery. core support to battery.
Scott91370
Burleson, Tx
Scott
Sierra1500
And a new one from the battery to everything.
Truck82
Alderton
Christopher
Any ideas?
What does the ohm meter show exactly? There should be about 0.1 ohms of resistance with absolutely no current running through the circuit. Isolate the wire when reading ohms.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I bet you will find either a loose ground wire, or bad corrosion inside the insulation of the heavy ground wire.
Since the main ground wire is compromised, the smaller ground wire is trying to pick up the slack. The starter is pulling far more current than the wire can handle, causing the internal smoke to vacate. Everyone knows smoke is what makes electrical things work. Once the smoke is let out, electrical stuff stops functioning!!
Start with the dash cluster. There should be a black ground wire up high under the dash. On an '87 I think there is a ground bus it connects to on the firewall, and older trucks the ground is a post on the top of the emergency brake.
Then make sure the large 2 gauge ground wire on the battery connects to the alternator bracket or some other substantial part of the engine. Use a wire brush and/or sandpaper to clean down to bare metal, and make sure it's really grounded well. The battery end of it should also have a smaller wire molded on, and it will connect to a ground point on the radiator support. There should also be a ground on the back of the engine on the passenger side, running over to the firewall, and thick braided ground from the engine over to the frame rail on the passenger side.
Also take out the front turn signals and make sure each one has a ground wire, and then clean off the rust where its screwed into the body and reground each light.
In the back of the truck right above the point where you would have a trailer hitch, there should be a white ground wire for the rear light harness, and it should be grounded to the frame.
There may be a couple more ground points on an '87 since it has fuel injection and more electrical devices than the older trucks.
the poor decision to use the thermostat housing to ground the PCM and run the engine ground was a poor choice
Dejure
Eastern Washington
Kelly
C15
My FIRST suspect would be, the ground connections (both ends) of the burned wire.
Bad connections act like resistors that, if you put a volt meter across them (power applied), show voltage of any significance. Even on the ground side.
Next, the main ground cable connection to ground. That is, that the little wire was trying to do some or all of the work of the big boy, but for circuits other than those the main ground cable was installed for.
As others point out, ground straps and cables from the battery to the frame, engine to frame, lights to frame and so on are a must.
I've seen a few occasions when an unrelated circuit completed another, unrelated circuit (path of least resistance, and all that).
[RABBIT TRAIL] One was not related to grounds. A bulb burned out, and the broken filament wire welded itself to the other bulb circuit in the process, giving head scratching symptoms (dash lights coming on with the press of the brake).
On that one, an ohm meter, used the usual way, would lead you to believe the bulb was fine (no open circuits). A casual visual inspection with turns and flashers lit the bulb, so in the light of day, you were inclined to think the bulb was fine. Good vision revealed an interesting result of a bulb gone south (verified by an ohm reading between the two positive contact points, versus just checking the positive points to bulb ground.
In the end, this is a good reminder, to me and others, part of the restoration and maintenance of our toys, uh, tools is, check for voltage drops (power on) or significant ohm readings (power off) where neither of the two should be seen, then respond appropriately for the readings.
SIDE NOTE: I bought a large tube of non-conductive grease to use on light bulb and fuse sockets, to cut down on the amount of oxygen that can get to the plugs and connectors.
For example, Super Lube 91003 Silicone High-Dielectric and Vacuum Grease, 3 oz.​
Carb'ed Vortec 350
OP, did you get this fixed?
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
The small ground was carrying all the current. The big cable is your problem. Not connected, bad connection , etc.
Perform a voltage drop test and diagnose the issue instead of guessing.
LordBruce
Burnaby, British Columbia
https://camptraveltrailer.com/listing/1977-gmc-frontier-18ft-motorhome-ready-to-use/
https://camptraveltrailer.com/listing/1977-gmc-frontier-18ft-motorhome-ready-to-use/ my running lights as well all are not working so need to put all new lights on the as well! The camper separate from the factory of the Van/Camper, camper has it's own fuse box under fridge under hot water tank. good place for it! not
I have headlights and signal in front just back, no Tail lights in back, only 1 signal on right and left makes it like the hazards are on, and no lights at all, so grounding is what I believe is the issue, down by the starter the frame has a metal braided wire from frame and I think it has to do with grounding the starter the base part to the frame, and the alternator I need to check if ground is on aswell, so I should have also gas tank ground to body/frame and the emergency break upper inside cab should have ground to body?
Sad Sack
Omaha, NE
Goober
C15
OP has left the building...
Rome03
