ls swap sm465 with headers now slave cylinder will not fit
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Like title says the slave cylinder will no longer bolt up because the headers are blocking it. This is a frame up rebuild and i did not see this coming. Its way too long to bolt in. So, is hydraulic throw out bearing and a new master cylinder my only choice and if so which one.
Thanks, BC
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Anyone Anyone?
nvrenuf
Mobile, Al.
I got nothing because of no LS experience.
Are you on FB?
Pic please. Would you have room to go with a pull type slave,instead of a push style slave.Wilwood and some others make them. Probably on your own fabbing rear bracket.
Old Guy Bill
KY
Bill
Don’t be afraid to “modify” the headers… :)
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
I had no idea that even existed. thank you so much. I will take a pic and post it this evening.
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Thanks Guys I will post some pics this evening.
nvrenuf
Mobile, Al.
In the "Classic Truck Federation Badass Trucks" group (sort of a Gulf Coast group) there's a guy name TC Cameron that's currently working on a square body with an LS / manual trans (2wd) using a hydraulic T/O bearing, he may have some info for you.
SquareRoot
One step forward, two steps back. Been there...
SquareRoot
Huh,gotcha beat I am absolutely positive I've been 1 step forward 97 and half steps backwards more than once
In this case, I would probably opt for the hydraulic t/o bearing . Another example of why headers suck. Hooker manifolds for the win.
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
Here some pictures
Ole Buck
Lower Alabama
Brad
V10 SWB 4x4
5.7 for now
See below
cutlerfab
