AM/FM Radio
Turbo4whl
Downingtown, PA
Wayne
Is this what GM called the multiplex stereo or something like that?
I think that meant the tuner would grab the FM stereo signal if it was available. Usually lit a light too.
The reverb dash control I don't have, stated Reverb.
j69shep
Scottsdale, AZ
jim
Yes that’s the multiplexer. I’ll see if I have anything that explains your reverb connections
j69shep
Scottsdale, AZ
jim
Upon further examination that’s a Motorola reverb. I don’t have a schematic for it. I’d need to get a closer look at the inside of the unit to figure out power, input and output. Yes these units typically had a 3 position switch on the dash that switched between front speaker reverb to rear speaker and reverb off. It looks to be a 65 unit. I’m not sure which models came with the Motorola unit. Maybe a riviera. Not sure. If you can get me a good shot of the inside of the unit near that 4 pin connector I could get you a good educated opinion.
Turbo4whl
Downingtown, PA
Wayne
@j69shep Looks like a lot going on from the drawing of the dash control. Transformer and other components beside just the switch control. Without that I am done.
I'm at camp today on staff for a scout activity. I send pictures later
j69shep
Scottsdale, AZ
jim
Okay sounds good. Can I ask what this is going into? I'm not sure you need the transformer it's likely just used of coupling anyway. The 67 and up don't use it. With that you could just use a 3 way switch to turn on and off the reverb and front speaker. I'll see what I can come up with once I hear back from you. Enjoy the day. Jim
Corvette Ed
East Tennessee
Eli
I used to find them at pick and pull yards. Most had problems with scratchy controls. Bought cans of spray contact cleaner and drenched the inside with it while moving the knobs. Nearly everyone one came out of it. In the last few years those radios have dried up.
Keep in mind GM used the same radio in cars. Only mounting brackets and knobs were different.
I’ve picked up several at swap that didn’t work or unknown condition from free to $5. A lot of the time contact cleaner will do the trick!
j69shep
Scottsdale, AZ
jim
I find them at swap meets. Typically they have one bad output channel which affects 2 speakers. Most have either the AM or the FM inoperable or the usual low volume problem. The good news is GM made a lot of them and there are still plenty of parts available to get one going again. Once refurbished and dialed in these radios play great and drive 4 speakers with plenty of volume. I add Bluetooth to them and it works great for playing any streaming service. Messages me for details. Jim
Turbo4whl
Downingtown, PA
Wayne
Jim, I started a new thread for the reverb questions.
CLICK HERE
hey mister
North Coast
Marty
The issue with buying an old stock replacement is most likely the same issue you're having with the original.
Some of the components in the radios are diaelectric capacitors. Over time they dry out and go out of tune.
The only fix is to replace the caps and whatever else.
I had that issue with the original AM in mine.
I found a RetroSound at Summit, in the discount rack. It was for an older ford, but for the price, I couldn't care less. That thing was loaded. BT, Sirus, AM/FM, 2usb ports for thumb drives and international stations.
It took me 3 tries to get in the dash. The truck kept spitting it out...lol
Somewhere in here is the retrofit post.
Turbo4whl
Downingtown, PA
Wayne
Very funny!
jbwhitford
