FRONT FENDER COWL CAGE NUT Gone
AndyL
Front fender cowl cage nut missing. I'm finally ready to put my new fenders on my 85 chevy c10 and noticed the cage nut on the inside of the cowl that is used to bolt the top of the fender to the cowl is gone. Pulled the dash apart along with the ac duct and there is no way to get to that area from the inside of the cab. Only thing I can think of is using a hole saw and cut a new hole on the inside of the cab under the dash even with where the hole is on the outside of the cowl. Without that bolt there the fender wont line up with the door. Anyone else ran into this?
I just broke mine off about a month ago putting my fenders back on after doing door hinges :893Chainsaw-Smilie-:banghead::angry94::biggun::flame::Whoa::wtf2::suicide::suicide: My fender still lined up pretty decent using the top bolt that goes down into the cowl, under the hood.
legopnuematic
Licensed Junk Dealer
MO
Spencer
What is missing? On the a pillar by the door jamb, or the bolt on the cowl that is under the hood?
Missing like missing, missing? Or stripped or? We need pics.
There are potential solutions to either, but different solutions.
legopnuematic
MO
Spencer
In the a pillar? Have you tried to drill it with a right hand drill bit?
The idea is if it grabs, it will thread itself in and just fall into the cavity, then chase the threads and install new bolt.
Use a drill appropriate diameter for a tap drill, either 1/4-28 or 5/16 (coarse or fine is fine). If the drill doesn’t get it moving, tap it, tap might get it moving, if not, use a bolt and jam it in to attempt to thread it in.
Yeah, the one in the A-pillar. I think mine stripped but is still there. I need to go look at our A-pillar assembly on the shelf and see how it's attached. Not sure if it's a cage nut or what but the bolt would still spin, just not tighten up. I was able to get it out by prying underneath it
mxer147
Colorado
Jack
k20
I welded the cage nut to a washer. I then drilled four new holes around the sheet metal where the cage nut belongs. I then put the washered cage nut where it belongs and held it tight with a bolt threaded into the nut. I then welded the four drilled holes since the washer lined up with them. I will chase the treads with a tap and lubricate before I use it to attach the fender.
legopnuematic
MO
Spencer
This is how my 79 is/was, I recall the donor pieces from an 85 were the same construction.
Fuuuuu. I'm not cutting my truck open until it's ready for paint, so it'll just live like it is for a while lol
AndyL
Sorry about the delay. It is the cage nut that came loose inside the pillar and dropped down into never never land. I bough a pack of 3/8 rivet nuts and a large rivet nut tool (looks like a pair of bolt cutters off Amazon. Worked great, was flush with the pillar, was able to really crank on the fender bolt.
Toad455
North Texas
Kevin
I just saw this and was going to recommend the rivet nuts but you already did that. I just used those to fix the stripped holes on the firewall for the blower housing since there aren't any nuts, only extruded holes with about one thread. I used 1/4 x 20 with the same amazon tools, worked great.
clee
