A little bit of everything for sale! 73-91
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Supposed to be 84 tailgate trim. Will check the rest of the bolt holes. Both pieces have a couple of dings. Nothing terrible.
BearKing
Black Hills
Bear
You wouldn’t happen to have a 350 Turbo with the 205 T case, would you?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I do not. I have a 2wd th350, but I wasn't planning on getting rid of that unless I found a decent th400 maybe. Otherwise I've got 2 465/205's and 2 divorced 205's, that I've got plans for as well.
A short tail housing 2wd th350 would be your next best bet, you can cut the transmission output shaft down, then I believe ORD sells an adapter shaft coupler or different t case inputs. They have the t case adapters as well. If you've got the 205 already. I remember glancing at your post about it
BearKing
Black Hills
Bear
Thanks ,Prairie
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Some gmc emblems, are these the elusive years?! In good shape, seems to be no cracks or broken stuff. Picked em up in a package deal with a bug deflector.
The studs are all good on the tailgate emblem.
Aren't all years of the GMC emblems the elusive ones?
I'm really curious about the one with all the mounting tabs and what it fits.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I guess they are all elusive pretty much lol.
I saw one on eBay but it just says 81-87. Maybe a big truck? But the tailgate emblem wouldn't have came with the big truck. I figured that the one with tabs wasn't a light duty emblem.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
The Dana 60 hubs are sold and the clips for the lower tailgate trim are sold.
legopnuematic
Licensed Junk Dealer
MO
Spencer
The GMC badge with tabs should be from a Medium duty.
The other one might be from a Top Kick, or not.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
That's what I was thinking. There were a lot of those trucks around here back in the day. A lot of guys up here still use the medium duty stuff for the farm, some have one as an extra backup or for weird jobs.
BryanS
Ft Pierce FL
Bryan
Blazer K5
Is this metal or rubber ?
Tonimus
Phoenix
Tony
C10 Suburban
What would you have to get for the OE steering wheel? Mine is starting to get sticky.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
That one is sold. I do have another from my 76 I would get rid of, will have to get pics up.
cutlerfab
