SBC 400 intermittent lifter tick.
Edelbrock
Earth
Grumba
K5 Blazer
Keep it under 3.5K RPM and it never ticks.
Rev it up to 5K RPM intermittently and it never ticks.
Hold the RPM above 3.5K for 5-10 minute and it taps badly.
Once it starts tapping badly, if you let it idle or drive with low RPM for 5-10 minutes, the tap slowly goes away and then disappears.
TAP TAP TAP. Not an exhaust leak, this is a hard lifter tap.
Lifter being starved? Lifter hanging up? Push rod magically shrinking in length and then lengthening itself after you stop rapidly spanking it?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Sounds like a weak lifter. Could try running some new engine in a bottle or thicker oil to try and help. What oil are you running now?
Otherwise valve adjustment may help some. If you've never messed with it anyways.
fast 99
Spokane, Washington
aerated oil or bad lifter? Like most everything else today lifter quality has fallen.
Edelbrock
Earth
Grumba
K5 Blazer
I was running 10W40 but after noticing the tick after prolonged high RPM, I switched to 20W50. Problem remains.
Should I try 5W30?
Try an engine flush?
Add a quart of trans fluid to the engine for a few hundred miles and then change the oil?
Pull the valve cover and check the rockers with a feeler gauge?
Should I pull the intake manifold and replace all the lifters and pushrods?
fast 99
Spokane, Washington
my 2 c
Check valve adjustment first it's possible nut backed off or worn cam/valve train parts to near zero lash.
If engine hasn't been maintained ATF might help but I doubt thinner oil would.
I know folks have had problems with offshore lifters. If you do decide to replace them buy name brand. You will have a better luck. Notice I said luck, after installing hundreds of engines it is just that, luck.
Edelbrock
Earth
Grumba
K5 Blazer
my 2 c
Whats the best way to check the adjustment? Motor: 400, unknown cam. Late 70's motor?
fast 99
Spokane, Washington
Valve adjustment with hydraulic lifters 3/4 to 1 down turn from zero lash.
With each valve closed loosen valve adjustment nut until push rod starts to turn easily with 2 fingers. That should be near zero then an additional 3/4 to 1 turn down. Engine will need to be rotated several times. There is a sequence where it can be done in a couple engine rotations provided a stock cam. May be someone else has that sequence. Should also be a you tube video that demonstrates it.
Hard
